The Insert URcap has a maximum radius of 10 mm that it goes to before the program halts. Is there anyway to increase the maximum radius on the URcap beyond that? If not could i potentially create my own insert spiral node using the polyscope?
I’m not sure I know what you’re talking about here…If this is a specific URCap, you may have better luck posing this question to the creator. However, yes, you could create your own script to create a spiral and just insert a script node and call that. Or make your own URCap.
