[URsim] Start the robot automatically
Hi there!
I’m trying to set automatic tests for my application using URsim but I am having problems with its initialization. Is there a way to skip the Confirmation of applied Safety Configuration (set it by default) and power on the robot automatically?
Hi David.
You can avoid the Confirmation of applied Safety Configuration by placing a default.installation file in the programs folder.
Regarding the power on and brake release you can control that via the dashboard server. Take a look here: Dashboard Server, port 29999 - 15690
Thanks a lot for your prompt response, I will try this right away!
using only brake release will power on and release the robots brakes in one step :wink:
