URCaps with images on buttons, in PolyScope 5
In the old PolyScope, URCaps with images on the buttons works fine, in PolyScope 5 the result is a bit different
Udklip
Is there a way to split the title and text on the button? With that I can put usable text in the menu, but keep the image in top of the page still.
Udklip
@anon82484413 did you find a way by any chance?
I guess the solution is using plain text for both cases right?
Yes, the only solution I found, was to only use text.
