UR10e: Fault C262A17: Failed to communicate with Elbow joint.
Getting this failure when I updated UR10e from 5.17 to 5.22.0
(Universal Robots - Robot Image - UR-Series & e-Series - SW 5.22.0)
What would have caused this ? And how do I resolve ?
Hello.
Have you tried these methods: Try the following actions to see which resolves the issue: (A) Make sure the cable between Control Box and Robot Arm is correctly connected and it has no damage, (B) Check for loose connections, (C) Conduct a complete rebooting sequence.
If it still error, try “downgrade” to old version.
