Hello, I wrote a send_cartesian_pose function by referring to test_move.py in Universal_Robots_ROS_Driver. This function uses pose_based_cartesian_traj_controller. Now I have a problem, I give the end Cartesian attitude point of the robotic arm (-0.59497, 0.40534, 0.07247, 3.43, 3.269, -0.184), (-0.59497, 0.40534, 0.07247, 3.580, 2.442, -1.089), among which only Rx,Ry and Rz have changed. Ideally, only the wrist 3 of the UR5 robot arm rotates, but the actual situation is that all 6 axes of the robot arm rotate. Could you please tell me how to make only wrist 3 rotate, thank you
Related topics
| Topic | Replies | Views | Activity | |
| How to use the cartesian trajectory controller? | 0 | 812 | June 5, 2023 | |
| Robot not executing pose in ROS | 0 | 225 | October 24, 2023 | |
| How to move UR by publishing pose into /ur_hardware_interface/script_command in Python | 9 | 8263 | May 12, 2021 | |
| Cannot obtain control resources for Cartesian pose control on UR5 from ROS Melodic on Ubuntu 18 RT | 0 | 603 | May 4, 2023 | |
| About the Cartesian trajectory controllers and Movegroup | 4 | 2715 | January 24, 2022 |
