Socket_read_ascii_float receives ? in polyscope
socket_read_ascii_float receives ? in polyscope . trying to send float values from python via socket connection but polyscope reads it as ? and when try to send integer using socket_binary_integer command it reads -1 which .
Maybe post the python as well so we have the other half of the puzzle
Echo client program
import socket
import time
HOST = “10.220.30.38” # The remote host
PORT = 30002 # The same port as used by the server
#print “Starting Program”
count = 0
s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
s.bind((“”, PORT)) # Bind to the port
s.listen(5) # Now wait for client connection.
print(“listening”)
c, addr = s.accept() # Establish connection with client.
while (count < 1000):
try:
msg = c.recv(1024)
# print msg
time.sleep(1)
if msg == “asking_for_data”:
count = count + 1
# print “The count is:”, count
time.sleep(0.5)
# print “”
         c.send("(2.0)");
        # c.send("(200.0,50.0,45.0)");
         print ("Send 200, 50, 45")
 except socket.error as socketerror:
#print count
         c.close()
s.close()
#print “Program finish”
reposting the code for anyone who wants to read it a little easier (three backticks on each side)
import socket
import time
HOST = "10.220.30.38"  # The remote host
count = 0
s.bind(("", PORT))  # Bind to the port
print("listening")
try:
    msg = c.recv(1024)
    time.sleep(1)
    if msg == "asking_for_data":
        count = count + 1
        time.sleep(0.5)
    c.send("(2.0)")
    print("Send 200, 50, 45")
    c.close()
s.close()
