Socket communication to get integer & float arrays
Got very strange behaviour with socket communication, getting both float values & integer with socket_read_binary_integer and socket_get_ascii_float in the same code .
UAOpen=False
while True:
if UAOpen!=True :
	UAOpen=socket_open("127.0.0.1", 4841,"socket_UA")
else:
	socket_send_string("float","socket_UA")
	global UA_InputsFloat=socket_read_ascii_float(24,"socket_UA")
	socket_send_string("int","socket_UA")
	global UA_InputsInt=socket_read_binary_integer(24,"socket_UA")
Using it the integer array values are wrong : 3 bytes right shifted !!! The float array still OK.
When putting a comment for float request all is OK with the integers.
But it’s also OK using two separated sockets, such as:
while True:
if UAOpen!=True :
	UAOpen=socket_open("127.0.0.1", 4841,"socket_F")
	socket_open("127.0.0.1", 4841,"socket_I")
else:
	socket_send_string("int","socket_I")
	global UA_InputsInt=socket_read_binary_integer(24,"socket_I")
	socket_send_string("float","socket_F")
	global UA_InputsFloat=socket_read_ascii_float(24,"socket_F")
Any idea ?
Server in C# code, same problem with gcc application:
 static void Main(string[] args)
        ListenForClients();
    private static void ListenForClients()
        try
            TcpListener tcpListener = new TcpListener(IPAddress.Any, 4841);
            tcpListener.Start();
            for (; ; )
                TcpClient client = tcpListener.AcceptTcpClient();
                Thread clientThread = new Thread(new ParameterizedThreadStart(HandleClientComm));
                clientThread.IsBackground = true;
                clientThread.Start(client);
        catch { }
    private static void HandleClientComm(object client)
        TcpClient tcpClient = (TcpClient)client;
        NetworkStream clientStream = tcpClient.GetStream();
        byte[] buffer = new byte[256];
        try
            for (; ; )
                int nb = tcpClient.Client.Receive(buffer);
                Console.WriteLine(Encoding.ASCII.GetString(buffer));
                if (Encoding.ASCII.GetString(buffer).Contains("int"))
                    byte[] Reponse = new byte[4 * 24];
                    for (int i=0;i<24;i++)
                        byte[] b = BitConverter.GetBytes(i);
                        Array.Reverse(b);
                        Array.Copy(b, 0, Reponse, i * 4, 4);
                    tcpClient.Client.Send(Reponse);
                else
                    String s = "(";
                    for (int i = 0; i < 24; i++)
                        if (i != 23)
                            s = s + i.ToString() + ",";
                        else
                            s = s + i.ToString() + ")\n";
                    tcpClient.Client.Send(Encoding.ASCII.GetBytes(s));
        catch { }
