Trying to send a hex string from PC and trying to read it on UR5e polyscope
import socket
host = ‘192.168.178.75’ # replace with the IP address of your UR5e
port = 30002
s.connect((host, port))
s.send(“Anirudh_Gowda\n”.encode())
data = s.recv(1024)
s.close()
print(“Received”, repr(data))
I am trying to send a hex string, but there a normal string from my PC to a UR5e, and i want the robot to recive the string give me a popup after checking the connection is established. For this the URscript that i am using is as follows.
host = “192.168.178.75”
port = 30002
socket_open(host, port)
while True:
data = socket_read_ascii_string()
if data == “Anirudh_Gowda”:
popup(“Message received: Anirudh_Gowda”)
sleep(0.1)
socket_close()
But currently i am not successful in reading the string, is there any suggestion on what i should change and redo???
Please help
