Shutting off a tool when a fault condition is met
Hello
first a description of what we are doing .
We are using a orbital sander on a Ur 10 E
and the sander is enabled and Disabled thru the Ur set function.
so currently if our system Has any type of fault the robot kicks out but the sander continues to run.
Can any one point me to a method that will disable the sander when the platform has a fault?
If your tool is controlled by a digital signal or modbus, you can set it as “low when not running” as the following picture.
