Sensor on the endarm
Hello Everyone,
I need to mount the sensor on the Tool of the robot. I will use sensor signal as Digital Input. Is it possible to use Connector (near the tool flange) for such purposes?
If not, can you recommend any company which produces the wires for dynamic environment?
Regards,
Giorgi
Hi @giorgigedaminski,
Of course, you can use the flange connector to connect the sensor and receive/set digital data. Check the instruction manual of your robot model, there you will find a description of the pins in the connector and the type of connector so you will know how to connect it.
Best!
Wojciech
Thanks a lot. I’ll check it.
