I am trying to send script commands with Python, and got some of it working
import socket
import time
s.settimeout(2)
s.connect(('192.168.1.99', 30002))
def sendCommand(cmd):
#cmd = 'def program():\n ' + cmd + '\n end\n'
cmd = cmd + '\n'
s.sendall(cmd.encode())
while (1):
sendCommand('set_digital_out(0, False)')
time.sleep(1)
sendCommand('set_digital_out(0, True)')
time.sleep(1)
As this it works, and turns the digital out 0 on and off. But if I try to wrap it in program() instead, nothing happens. Am I sending it wrong? Or does it expect to receive the function different?
I know I don’t need to put it like that for just a single command, but it is in preperation for something more exciting.
Why is it I always find the problem right after posting here???
The problem was the space in “\n end\n”
import socket
import time
s.settimeout(2)
cmd = 'def program():\n ' + cmd + '\nend\n'
print(cmd)
while (1):
time.sleep(1)
time.sleep(1)
This works, and will just toggle digital out 0 on and off.
The python code works great, I am using the URScript manual to send commands to the robot and it is fine
In the other hand, some commands should get an answer from the robot like get_actual_joint_positions(), I tried the s.recv(1024) but I get a lot of binary data, do you have an idea how to format the answer and get the right data ?
Thank you in advance
