S.send command in python
Hi, i´m trying to send → s.send (“set_digital_out(2,False)” + “\n”) , but i get TypeError: a bytes-like object is required, not ‘str’.
Does anyone know a solution? Thanks!
Code:
Echo client program
import socket
import time
HOST = “172.16.200.62” # The remote host
PORT = 30002 # The same port as used by the server
s.connect((HOST, PORT))
s.send (“running”+“\n”)
data = s.recv(1024)
s.close()
print (“Received”, repr(data))
Hello I would suggest using the encode methode.
msg = “set_digital_out(2,False)” + “\n”
s. send(msg.encode())
to print the received data i would use print(data.decode())
Thanks!! Nice week!!
Hello, the problem is for python3 you must change the SEND command like this:
s.send(str.encode(‘set_standard_digital_out(2,False)\n’))
