I am working with an UR5e in my university project. Currently I am trying to activate my gripper through setting the “Tool Digital Output 1” to true, which works when changing its value on the robots controller.
While searching for a way I found the possibility of sending an UR-Script command via a socket to the robot. While it seems to work for the examples I found, the value does not change for my robot.
Is my code (see below) correct or am I missing something?
s.connect(("192.168.12.200", 30002))
output = "set_tool_digital_out(1,True)"
s.send(output)
data = s.recv(1024)
s.close
print("Received", repr(data))
Specs:
Ubuntu 20.04
Python: 3.8
Robot: UR5e (Software Version: 5.12)
We found out, that everything was correct, we were just missing the “\n” after the command and forgot to turn the robot control on the controller on “remote control”.
Everything works as intended.
