Hi together, i want to control the UR10e 5.13.0 with Python RTDE 30004 and ProfiDev together.
When i activate Profinet IO Device, the python RTDE goes to
no TCP Connection to Robot 10.150.100.141 port 30004 ‘Cannot receive when RTDE synchronization is inactive’
ERROR:rtde:Cannot send when RTDE synchronization is inactive
ERROR:rtde:Unable to send: not connected to Robot
ERROR:rtde:RTDE synchronization failed to pause
The ProfinetDevice should only have the in/outs.
The Realtime is using
urrtdexmlfile = “”"<?xml version="1.0"?>
<rtde_config>
<recipe key="state">
<field name="actual_q" type="VECTOR6D"/>
<field name="actual_TCP_pose" type="VECTOR6D"/>
<field name="output_int_register_0" type="INT32"/>
<field name="output_int_register_1" type="INT32"/>
<field name="output_int_register_2" type="INT32"/>
<field name="output_int_register_3" type="INT32"/>
<field name="output_int_register_4" type="INT32"/>
<field name="robot_status_bits" type="UINT32"/>
<field name="output_int_register_11" type="INT32"/>
<field name="output_int_register_12" type="INT32"/>
<field name="output_int_register_13" type="INT32"/>
<field name="output_bit_register_64" type="BOOL"/>
<field name="output_bit_register_65" type="BOOL"/>
<field name="output_bit_register_66" type="BOOL"/>
<field name="output_bit_register_67" type="BOOL"/>
<field name="output_bit_register_68" type="BOOL"/>
<field name="output_bit_register_69" type="BOOL"/>
<field name="output_bit_register_70" type="BOOL"/>
<field name="output_bit_register_71" type="BOOL"/>
</recipe>
<recipe key="boolin">
<field name="input_bit_register_64" type="BOOL"/>
<field name="input_bit_register_65" type="BOOL"/>
<field name="input_bit_register_66" type="BOOL"/>
<field name="input_bit_register_67" type="BOOL"/>
<field name="input_bit_register_68" type="BOOL"/>
<field name="input_bit_register_69" type="BOOL"/>
<field name="input_bit_register_70" type="BOOL"/>
<field name="input_bit_register_71" type="BOOL"/>
</recipe>
<recipe key="setpose">
<field name="input_double_register_0" type="DOUBLE"/>
<field name="input_double_register_1" type="DOUBLE"/>
<field name="input_double_register_2" type="DOUBLE"/>
<field name="input_double_register_3" type="DOUBLE"/>
<field name="input_double_register_4" type="DOUBLE"/>
<field name="input_double_register_5" type="DOUBLE"/>
</recipe>
<recipe key="setbase">
<field name="input_double_register_6" type="DOUBLE"/>
<field name="input_double_register_7" type="DOUBLE"/>
<field name="input_double_register_8" type="DOUBLE"/>
<field name="input_double_register_9" type="DOUBLE"/>
<field name="input_double_register_10" type="DOUBLE"/>
<field name="input_double_register_11" type="DOUBLE"/>
</recipe>
<recipe key="settcp">
<field name="input_double_register_12" type="DOUBLE"/>
<field name="input_double_register_13" type="DOUBLE"/>
<field name="input_double_register_14" type="DOUBLE"/>
<field name="input_double_register_15" type="DOUBLE"/>
<field name="input_double_register_16" type="DOUBLE"/>
<field name="input_double_register_17" type="DOUBLE"/>
</recipe>
<recipe key="setjoint">
<field name="input_double_register_18" type="DOUBLE"/>
<field name="input_double_register_19" type="DOUBLE"/>
<field name="input_double_register_20" type="DOUBLE"/>
<field name="input_double_register_21" type="DOUBLE"/>
<field name="input_double_register_22" type="DOUBLE"/>
<field name="input_double_register_23" type="DOUBLE"/>
</recipe>
<recipe key="sendjob">
<field name="input_int_register_1" type="INT32"/>
<field name="input_int_register_3" type="INT32"/>
</recipe>
<recipe key="sendorderid">
<field name="input_int_register_4" type="INT32"/>
</recipe>
<recipe key="watchdog">
<field name="input_int_register_0" type="INT32"/>
</recipe>
<recipe key="setgrp">
<field name="input_int_register_11" type="INT32"/>
<field name="input_int_register_12" type="INT32"/>
<field name="input_int_register_13" type="INT32"/>
</recipe>
</rtde_config>“”"
Any Ideas ?
Greetings Tom
