Hi there,
I’m currently operating a safety scanner.
I would like to set the normal speed at 250 mm/s and the speed in the decrease mode at 250 mm/s or less in the safety setting, is this possible?
Definitely. As soon as you set up a Safety IO to activate Reduced Mode (or a Safety Plane). Then the fields will open up for you to edit them. ![]()
Thank you for your help. ![]()
