Operation mode controlled by dashboard server or I/O
I was testing to see if I could control the robot mode and switch back to remote. I failed miserably but now I can’t get rid of the auto/manual selection controlled by dashboard server or I/O. I want to get back to controlling it from the teach pendant. Does anyone know how?
Does anyone know how to factory reset an e-series? There has got to be a way around this.
You can’t just click the little button in the top right and select manual? Are you still constantly sending some dashboard command or something?
@mewescott,
You need to send a “clear operational mode” command over dashboard server to give control of Auto/Manual mode back to Polyscope.
As for using dashboard to switch between Remote/Local modes, the set operational mode dashboard commands will take the system out of Remote, but then a clear command must be sent, and Polyscope must be used to return to Remote mode.
