I want to work onrobot rg2 gripper in python
I succeeded in moving the robot using the urx library, but the operation of the gripper failed.
Currently, I am using an onrobot rg2 gripper, and I tried to operate it with the onrobot rg2 gripper api below, but it did not work.
The operating system is Windows and I want to run the gripper with Python.
I’ll be waiting for your help.
Below is my code.
ㅇ onrobot rg2 gripper API
(Support for OnRobot RG2 Gripper by Mofeywalker · Pull Request #45 · SintefManufacturing/python-urx · GitHub)
import urx
import time
from math import pi
from urx import onrobot_rg2_gripper
def rad(degree):
result = degree*(pi/180)
return result
rob = urx.Robot(“192.168.50.100”)
gripper = onrobot_rg2_gripper.OnRobotGripperRG2(rob)
a = 0.5
v = 1
rob.set_tcp((0,0,0.1,0,0,0))
rob.set_payload(2,(0,0,0.1))
time.sleep(2)
for i in range(2):
rob.movej((0,rad(-80),0,rad(-90),0,0),a,v)
time.sleep(2)
gripper.open_gripper(
target_width=110, # Width in mm, 110 is fully open
target_force=40, # Maximum force applied in N, 40 is maximum
payload=0.5, # Payload in kg
set_payload=False, # If any payload is attached
depth_compensation=False, # Whether to compensate for finger depth
slave=False, # Is this gripper the master or slave gripper?
wait=2 # Wait up to 2s for movement
rob.movej((0,rad(-100),0,rad(-90),0,0),a,v)
rob.close()
Hello, Unfortunately I dont know how exactly the code you sent is implemented in URX. The RG2 Gripper is not supported in the standard urx library you will have to use a fork that includes it.
What error are you getting if you try to run it?
Using the RG2 Gripper is possible even without dedicated functions in the urx API (for example if you dont want to use the fork of the library)
You need to add the “boilerplate script” before calling the RG2 command.
We just concatenate it as a long string before adding an RG2() function as a string as well.
This is the boilerplate script for the RG2 Grippers:
set_standard_analog_input_domain(0, 1)
  set_standard_analog_input_domain(1, 1)
  set_tool_analog_input_domain(0, 1)
  set_tool_analog_input_domain(1, 1)
  set_analog_outputdomain(0, 0)
  set_analog_outputdomain(1, 0)
  set_tool_voltage(0)
  set_input_actions_to_default()
  set_tcp(p[0.0,0.0,0.0,0.0,0.0,0.0])
  set_payload(0.0)
  set_gravity([0.0, 0.0, 9.82])
  # begin: URCap Installation Node
  #   Source: RG - On Robot, 1.9.0, OnRobot A/S
  #   Type: RG Configuration
  global measure_width=0
  global grip_detected=False
  global lost_grip=False
  global zsysx=0
  global zsysy=0
  global zsysz=0.06935
  global zsysm=0.7415
  global zmasx=0
  global zmasy=0
  global zmasz=0.18659
  global zmasm=0
  global zmasm=0
  global zslax=0
  global zslay=0
  global zslaz=0
  global zslam=0
  global zslam=0
  thread lost_grip_thread():
    while True:
      set_tool_voltage(24)
      if True ==get_digital_in(9):
        sleep(0.024)
        if True == grip_detected:
          if False == get_digital_in(8):
            grip_detected=False
            lost_grip=True
        zscale = (get_analog_in(2)-0.026)/2.9760034
        zangle = zscale*1.57079633+-0.08726646
        zwidth = 5.0+110*sin(zangle)
        global measure_width = (floor(zwidth*10))/10-9.2
      sync()
  lg_thr = run lost_grip_thread()
  def RG2(target_width=110, target_force=40, payload=0.0, set_payload=False, depth_compensation=False, slave=False):
    grip_detected=False
    if slave:
      slave_grip_detected=False
    else:
      master_grip_detected=False
    timeout = 0
    timeout_limit = 750000
    while get_digital_in(9) == False:
      if timeout > timeout_limit:
        break
      timeout = timeout+1
      sync()
    def bit(input):
      msb=65536
      local i=0
      local output=0
      while i<17:
        set_digital_out(8,True)
        if input>=msb:
          input=input-msb
          set_digital_out(9,False)
        else:
          set_digital_out(9,True)
        if get_digital_in(8):
          out=1
        sync()
        set_digital_out(8,False)
        sync()
        input=input*2
        output=output*2
        i=i+1
      return output
    target_width=target_width+9.2
    if target_force>40:
      target_force=40
    if target_force<4:
      target_force=4
    if target_width>110:
      target_width=110
    if target_width<0:
      target_width=0
    rg_data=floor(target_width)*4
    rg_data=rg_data+floor(target_force/2)*4*111
    rg_data=rg_data+32768
    if slave:
      rg_data=rg_data+16384
    bit(rg_data)
    if depth_compensation:
      finger_length = 55.0/1000
      finger_heigth_disp = 5.0/1000
      center_displacement = 7.5/1000
      start_pose = get_forward_kin()
      set_analog_inputrange(2, 1)
      start_depth = cos(zangle)*finger_length
      sleep(0.016)
      timeout = 0
      while get_digital_in(9) == True:
        timeout=timeout+1
        sleep(0.008)
        if timeout > 20:
          break
      timeout = 0
        measure_depth = cos(zangle)*finger_length
        compensation_depth = (measure_depth - start_depth)
        target_pose = pose_trans(start_pose,p[0,0,-compensation_depth,0,0,0])
          break
        timeout=timeout+1
        servoj(get_inverse_kin(target_pose),0,0,0.008,0.01,2000)
        if point_dist(target_pose, get_forward_kin()) > 0.005:
          popup("Lower grasping force or max width",title="RG-lag threshold exceeded", warning=False, error=False, blocking=False)
      nspeed = norm(get_actual_tcp_speed())
      while nspeed > 0.001:
        stopj(2)
    if depth_compensation==False:
      timeout = 0
      timeout_count=20*0.008/0.008
        timeout = timeout+1
        sync()
        if timeout > timeout_count:
          break
      timeout = 0
        timeout = timeout+1
        sync()
          break
      sleep(0.024)
      if set_payload:
        if slave:
          if get_analog_in(3) < 2:
            zslam=0
          else:
            zslam=payload
        else:
          if get_digital_in(8) == False:
            zmasm=0
          else:
            zmasm=payload
        zload=zmasm+zslam+zsysm
        set_payload(zload,[(zsysx*zsysm+zmasx*zmasm+zslax*zslam)/zload,(zsysy*zsysm+zmasy*zmasm+zslay*zslam)/zload,(zsysz*zsysm+zmasz*zmasm+zslaz*zslam)/zload])
      master_lost_grip=False
      slave_lost_grip=False
      if True == get_digital_in(8):
        master_grip_detected=True
      if get_analog_in(3)>2:
        slave_grip_detected=True
      grip_detected=False
      lost_grip=False
        grip_detected=True
      if slave:
        slave_measure_width=measure_width
      else:
        master_measure_width=measure_width
      return grip_detected
  set_tcp(p[0,0,0.18659,0,-0,0])
So the python script that uses it with urx looks like this:
import urx
rob = urx.Robot("192.168.0.100")
boilerplate =  """
  set_tool_voltage(0)
  set_payload(0.0)
  global zsysx=0
  global zsysy=0
  global zsysm=0.7415
  global zmasx=0
  global zmasy=0
  global zmasm=0
  global zmasm=0
  global zslax=0
  global zslay=0
  global zslaz=0
  global zslam=0
  global zslam=0
    while True:
        sleep(0.024)
            grip_detected=False
            lost_grip=True
      sync()
    grip_detected=False
    if slave:
    else:
    timeout = 0
        break
      timeout = timeout+1
      sync()
    def bit(input):
      msb=65536
      local i=0
      local output=0
      while i<17:
        if input>=msb:
          input=input-msb
        else:
          out=1
        sync()
        sync()
        input=input*2
        output=output*2
        i=i+1
      return output
    if target_force>40:
      target_force=40
    if target_force<4:
      target_force=4
      target_width=110
    if target_width<0:
      target_width=0
    if slave:
    bit(rg_data)
      sleep(0.016)
      timeout = 0
        timeout=timeout+1
        sleep(0.008)
        if timeout > 20:
          break
      timeout = 0
          break
        timeout=timeout+1
        stopj(2)
      timeout = 0
        timeout = timeout+1
        sync()
          break
      timeout = 0
        timeout = timeout+1
        sync()
          break
      sleep(0.024)
      if set_payload:
        if slave:
            zslam=0
          else:
            zslam=payload
        else:
            zmasm=0
          else:
            zmasm=payload
      grip_detected=False
      lost_grip=False
        grip_detected=True
      if slave:
      else:
grip_width_open = 40
open_grip_command = f"RG2(target_width={grip_width_open}, target_force=1, payload=1, set_payload=False, depth_compensation=False) \n"
grip_width_closed = 0
open_grip_command = f"RG2(target_width={grip_width_closed}, target_force=1, payload=1, set_payload=False, depth_compensation=False) \n"
robot_program = boilerplate + open_grip_command + close_grip_command
rob.send_program(robot_program)
let me know if this works
The program just hangs in my terminal but I get some errors on the teach pendant which are different errors upon subsequent runs.
Errors:
#value error: ‘timeout’ is not initalized to a value
#Value error: ‘input’ is not initalized to a value
#Value error: ‘i’ is not initalized to a value
#Value error: ‘rg_data’ is not initalized to a value
#Value error: ‘target_width’ is not initalized to a value
#RG-lag theshold exceeded, lower grasping force or max width
I checked all these variables and they are initialize. It must be close to correct. Any advice on how to debug this?
I have the same problem but with OnRobot SG. I’m trying to write a script to use the sg_grip and sg_release functions but when I try to send the script to the robot I receive a lot of “unitialization” messages even if the variables are initialized.
I even attempted to download the original script from polyscope (a working script) and send it later to the robot but I have the same problems.
Here use this library I developed to communicate with onRobot grippers with the Universal Robots (robots) through the standard m8 tool connector.
git@github.com:RyanPaulMcKenna/onRobot.git
Can pip install like so:
pip install onRobot
and use like so:
import onRobot.gripper as gripper
# Default id is zero, if you have multiple grippers,
# see logs in UR Teach Pendant to know which is which :)
rg_id = 0
rg_gripper = gripper.RG2(rg_id)
rg_width = rg_gripper.get_rg_width()
pregrasp_width = 100
# force and width units described in onRobot RG2 Manual
target_width = 15.66
target_force = 40.00
if (rg_wdith == pregrasp_width):
    rg_gripper.rg_grip(target_width, target_force)
epsilon = 0.05 # Just an example of reasonable error may not be realistic.
grip_success = abs(rg_gripper.get_rg_width() - target_width) < epsilon
thank you @fvr510 for the library.
This is probably the easiest way of using the rg2 gripper with pyhton.
for anyone who wants to use the RG2 gripper with the URX library, there was a small issue in the code I posted above.
I cant test it but what was missing was probably a program wrapper added to the code:
prog_start = "def Program():"
prog_end = "end \n Program()"
robot_program = prog_start + robot_program + prog_end
This is the full code:
import urx
rob = urx.Robot("10.10.10.22")
boilerplate =  """
  set_tool_voltage(0)
  set_payload(0.0)
  global zsysx=0
  global zsysy=0
  global zsysm=0.7415
  global zmasx=0
  global zmasy=0
  global zmasm=0
  global zmasm=0
  global zslax=0
  global zslay=0
  global zslaz=0
  global zslam=0
  global zslam=0
    while True:
        sleep(0.024)
            grip_detected=False
            lost_grip=True
      sync()
    grip_detected=False
    if slave:
    else:
    timeout = 0
        break
      timeout = timeout+1
      sync()
    def bit(input):
      msb=65536
      local i=0
      local output=0
      while i<17:
        if input>=msb:
          input=input-msb
        else:
          out=1
        sync()
        sync()
        input=input*2
        output=output*2
        i=i+1
      return output
    if target_force>40:
      target_force=40
    if target_force<4:
      target_force=4
      target_width=110
    if target_width<0:
      target_width=0
    if slave:
    bit(rg_data)
      sleep(0.016)
      timeout = 0
        timeout=timeout+1
        sleep(0.008)
        if timeout > 20:
          break
      timeout = 0
          break
        timeout=timeout+1
        stopj(2)
      timeout = 0
        timeout = timeout+1
        sync()
          break
      timeout = 0
        timeout = timeout+1
        sync()
          break
      sleep(0.024)
      if set_payload:
        if slave:
            zslam=0
          else:
            zslam=payload
        else:
            zmasm=0
          else:
            zmasm=payload
      grip_detected=False
      lost_grip=False
        grip_detected=True
      if slave:
      else:
close_grip_command = f"RG2(target_width={grip_width_closed}, target_force=1, payload=1, set_payload=False, depth_compensation=False) \n"
if someone tries this please report if it works.
Hi robin_gdwl.
The program still does not work.
