Is there a method to retrieve maximum payload using URScripts or RTDE? I need the payload value which was set and not the active payload value.
Thanks in advance.
Thanks in advance.
Hi Roshni,
no, you can only read out the current set target payload using the script command: get_target_payload()
What would be the use case you could solve with this feature?
