How can I create a movement template with the UR5 so that when the robot arm is moved to a new physical location, it has the correct coordinates?
if i understand your question correctly, you can make a feature on, let’s say a tabletop, and when you move the robot arm somewhere else, you can teach the feature again on the new table, and the coordinates will be according to the features coordinates.
see UR manual about features here
