Hi, we are programming on the Polyscope 5.25 with a UR20.
Is there a way do disable the point linking to each other on copy as a default ? We have big programs where we have to copy & duplicate parts of program to modify for a new dimension product. Having to manually un-link each point is so time consuming & often leads to error if we forget to unlink the points. Is there a way to disable this feature on copy by default ?
From my experience with Fanuc, when the points are copied, it asks if we want to create a link with existing ones or create new waypoints with the same coordinates.
Nope I don’t believe there is. It’s cost me quite a lot of time in the past as well.
Polyscope itself is not opensource right ? ie. There is no way to customise it for our use-case ?
