I am trying to use the Dashboard commands from my Beckhoff PLC to load and run scripts while also using the Profinet Fieldbus to control the UR5e from the same PLC and pull data from it. However, to run the dashboard commands, the Profinet Fieldbus has to be disabled on the UR5e to enable it to host the Dashboard server.
Is there a work around for this? Is there an example/way to play and load files using Profinet instead?
