Console commands
Is there anyplace which gives a basic but fairly comprehensive list of commands available on the console?
Just stumbled through logging in and finding the MAC address for our controller so I can have our IT dept. reserve an IP address, but we had to piece together info from a few different sources to figure that out, as they each had a slightly different take on it.
I don’t know if this would help, but they are all Linux commands, so Top 50+ Linux Commands You MUST Know | DigitalOcean should all be applicable. That being said, if you aren’t sure of the command that you are using, I wouldn’t use it, you can do some serious damage.
