C4A16 Communication Issue with Joint 4
I own a UR3 (serial # 2016331332). I am running PolyScope version 3.9.0.64176
Out of the blue, I started receiving the following error:
image.
I tried performing a complete reboot sequence but did not that change anything. What could I do to resolve this?
Thanks - Manish
Hello @anon91700237,
I would contact your local support team, or distributor for further assistance. They can help troubleshoot further, in the case of any issues with the communication wiring on the joint, they can also help you with the next steps if a joint replacement is needed.
When you contact them if you could provide a log file, serial number, and short description on when you encountered the error they can work promptly to resolve the issue.
Thanks Inu - I’m in touch with them and trying to get it resolved. I’ve sent over logs and photos to figure out more.
While I have you and your staffmates here - does anything seem off from any of the below?
Log dump: https://manish-dev-test.s3-us-west-1.amazonaws.com/2016331332.zip
Photo of J4 with cap removed: https://photos.app.goo.gl/oBx51hWTA6iGVxvs5
Video of J4 with cap removed: https://photos.app.goo.gl/E2P4UEZSKEkcdojQ9
I have the same problem. what was the solution?
