Before start function affect my palletizing routine
I have a palletizing routine (boxes) the problem is that if i use the before start to assign a routine if there´s a collision, the palletizing starts again on the first position. I want the UR to keep the last position. i dont have that issue if the before start is off.
My guess is that the before start resets the loop of the palletizing.
Does someone experienced this?
Hi, and welcome to the Forum!
The steps would generally be:
  • Create a new Installation Variable in Installation > Variables
  • Save the Item Counter value to this Installation Variable using the Assign Node, when a new item is picked up
  • In your Before Start Sequence, assign the Installation Variable to the Item Counter
Let me know if it makes sense!
