I’m trying to add a folder node directly under the root node in the tree but it’s always created under the last selected node.
This is the code that I use:
The UR API does not support multiple instances of ‘parent nodes’ to the program tree, in other words you cannot traverse the parent node you are located in. You can only add or update child nodes, which is why the folder appears as a child of the Ellipse node.
In this case another parent node could be created similarly to how the Ellipse node was created. (similar to the existing folder function under the basic commands tab)
