Visit URCap Nodes using the TreeNode.traverse(newProgramVisitor() {}
I have created a few childNodes for a parentNode and I want to visit some of them using this (TreeNode.traverse(new ProgramVisitor() { } )).
I have copied the code of Mr Jacob. Here is below:
TreeNode root = apiProvider.getProgramAPI().getProgramModel().getRootTreeNode(this);
// Traverse the program tree, using the ProgramNodeVisitor
root.traverse(new ProgramNodeVisitor() {
    // Override "visit" looking for "URCapProgramNode" nodes
    // Visit will be called for every URCapProgramNode in sub-tree
    @Override
    public void visit(URCapProgramNode programNode, int index, int depth) {
        // Check if the found program node implements the "MyCustomAPI" interface
        if(programNode.canGetAs(MyCustomAPI.class)) {
            // If it did, we found the right node
            // Now we can use "getAs" since we already tested with "canGetAs"
            // After "getAs" we can now call the interface methods
            programNode.getAs(MyCustomAPI.class).addPoss(poss, firstPoss);
This gets in every childNode which implements MyCustomAPI. I want to get only in 3rd and 5th childNodes of the same parentNode.
Thanks in Advance,
Mehmet Bilgin
@Override
	if (index == 2 || index== 4){
Adding if (index == … did the trick for me. Keep in mind that the counting of the siblings starts with zero.
Thanks,
