Someone that know about a vakuum sensor from Festo that works well with ur robot.
Did try a combo solid valves + vakumm sensor, but i don get this to work.
Hi Espen,
To get the right advice, you need to provide more details about your application, such as what exactly you are trying to do with the sensor and cobot, how you connected it, and what exact model of vacuum generator you are using (each model has a different type of digital output).
Regards
Anibal Hillier
Did get it to work.
It must something fault with the cable i used, did change it with a different cable.
I’m glad that you could get it to work
Regards
Anibal Hillier
