Problem Description
I’m simulating two UR10e robots in Gazebo using PositionJointInterface and the JointTrajectoryController. The robots exhibit severe twitching and oscillation immediately after launching the simulation environment, even without any commanded motion. The robots are unstable at their initial configuration and continuously vibrate/shake. I was using EffortJointInterface earlier, but never encountered this problem.
Setup
ROS Environment: Gazebo simulation
Robots: 2x UR10e with separate namespaces
Control Interface: hardware_interface/PositionJointInterface
Controller: position_controllers/JointTrajectoryController
Spawn Configuration: One robot at origin (0, 0, 0), second at (1.3, 0, 0)
Configuration Details
URDF Transmission (per joint):
<transmission name="shoulder_pan_trans">
<type>transmission_interface/SimpleTransmission</type>
<joint name="shoulder_pan_joint">
<hardwareInterface>hardware_interface/PositionJointInterface</hardwareInterface>
</joint>
<actuator name="shoulder_pan_motor">
<mechanicalReduction>1</mechanicalReduction>
</actuator>
</transmission>
Controller YAML File
joint_state_controller:
type: joint_state_controller/JointStateController
publish_rate: &loop_hz 125
pos_joint_traj_controller:
type: position_controllers/JointTrajectoryController
joints: &robot_joints
- shoulder_pan_joint
- shoulder_lift_joint
- elbow_joint
- wrist_1_joint
- wrist_2_joint
- wrist_3_joint
constraints:
goal_time: 2.0
stopped_velocity_tolerance: 0.02
shoulder_pan_joint: {trajectory: 0.2, goal: 0.05}
shoulder_lift_joint: {trajectory: 0.2, goal: 0.05}
elbow_joint: {trajectory: 0.2, goal: 0.05}
wrist_1_joint: {trajectory: 0.2, goal: 0.05}
wrist_2_joint: {trajectory: 0.2, goal: 0.05}
wrist_3_joint: {trajectory: 0.2, goal: 0.05}
stop_trajectory_duration: 0.5
state_publish_rate: *loop_hz
action_monitor_rate: 20
joint_group_pos_controller:
type: position_controllers/JointGroupPositionController
joints: *robot_joints
gazebo_ros_control:
pid_gains:
shoulder_pan_joint: {p: 15000, i: 50, d: 500, i_clamp: 50}
shoulder_lift_joint: {p: 15000, i: 50, d: 500, i_clamp: 50}
elbow_joint: {p: 8000, i: 30, d: 300, i_clamp: 50}
wrist_1_joint: {p: 300, i: 5, d: 10, i_clamp: 10}
wrist_2_joint: {p: 300, i: 5, d: 10, i_clamp: 10}
wrist_3_joint: {p: 50, i: 1, d: 5, i_clamp: 5}
Gazebo Plugin:
<gazebo>
<plugin name="gazebo_ros_control" filename="libgazebo_ros_control.so">
<robotNamespace>$(arg robot_name)</robotNamespace>
</plugin>
</gazebo>
Launch Configuration:
<include file="$(find gazebo_ros)/launch/empty_world.launch">
<arg name="paused" value="$(arg paused)"/>
<arg name="use_sim_time" value="$(arg use_sim_time)"/>
<arg name="gui" value="$(arg gui)"/>
<arg name="headless" value="$(arg headless)"/>
<arg name="debug" value="$(arg debug)"/>
</include>
Observed Issues
Immediate oscillation: Robots start twitching/vibrating as soon as Gazebo loads
No commanded motion: Issue occurs before any commands are sent to controllers
Continuous instability: Oscillation persists indefinitely at initial pose
Both robots affected: Issue occurs on both robot instances independently
Visual shaking: Links visibly shake and jitter in the Gazebo GUI
What I’ve Tried
Adjusted PID gains extensively (reduced P, increased D, adjusted I and i_clamp)
Reduced controller publish rate (500Hz → 125Hz)
Questions
Are my PID gains appropriate for UR10e position control in Gazebo?
Is there a known issue with PositionJointInterface stability at startup?
Should controllers be initialized with a specific hold position command?
Could this be related to Gazebo physics parameters (timestep, solver iterations)?
Is there a controller “warm-up” or initialization procedure I’m missing?
Additional Information
Controllers load successfully (confirmed via rosservice list and controller_manager)
No error messages in console or Gazebo logs
Any insights or suggestions would be greatly appreciated!
