Is there an API function available to Suppress the current URCAP created program Node?
Similar question for ‘Delete’ the current URCAP created program Node ?
Functionality should be equal to what is there available in the Structure tab with buttons ‘Suppress’ and ‘Delete’.
Reason for this request: having a ‘Suppress’ and ‘Delete’ button in the (URCAP defined) ‘Command’ tab will be much easier then first switching to ‘Structure’ tab and back again to ‘Command’ tab.
u can use the function removeChild() of a TreeNode Object and search the Node to be deleted with getChildren()
for rootTreeNodes itself it is not yet possible
