UR10 work with 2 PSU 48VDC supply . is it able to run with only one ?
I would like to put one of an UR10 safe on another UR10 defect …
I have never done it before personally, but if you wire a single 48V supply to both 48V inputs, then the controller should accept it.
You will have to run with very low accelerations, I can imagine. ![]()
Thanks efn , i just received 2 brand new 48V supply and a current distributor so i will fix my problèm .
Glad to hear that.
It’s always a little risky not doing things how they’re supposed to be done.
