I’m facing a problem with an integration to an instrument, we use to integrate this way:
Socket_Connect=socket_open(“192.168.2.175”,50012)
socket_send_string("<command name=")
socket_send_byte(34)
socket_send_string("AssumeControl")
socket_send_string(" />")
socket_send_byte(10)
data=socket_read_string()
code_pos=str_find(data,"code")
code_str=str_at(data,code_pos+6)
code_num=to_num(code_str)
socket_close()
With the string:
Sent as above with a newline in the end.
Now the integration seems not to accept to get the TCP packets sent in pieces. I would like to find a way to concatenate a string with double quotation marks inside and send i all in one go.
Is there a way?
I can only find the above as being supported and it feels strange that you can’t escape an "
Very happy for all help I can get in this matter
Seems like the forum has the same problem
My string in the post is not showing Trying again here to quote it:
command name=“AssumeControl” />
