Run magic files in the URCap
hello, I have a folder with the script inside that is used to install VNC and I would like to make a URCap that goes to run the script and install VNC. I have done various tests but I can’t run the script. i use the Polyscope simulator. What should I do?
URMagic_VNC_Installation_V1.zip (3.5 MB)
I’ve not done this, and UR doesn’t really endorse custom magic files, but I would assume as long as the script file you’re trying to run has been packaged with your CAP, you can just run the file when the Activator loads or something. Just Google something like “run .sh file java.” I’m sure something will come up.
I have already tried doing this but nothing happens. I thought that most likely the .sh file I have is specially made to run it on a real Polyscope and not on a simulator.
