Robot not booting, sometimes only
Steps to reproduce:
Power on robot.
Expected Behavior:
Robot powers on.
Actual Behavior:
Robot does not power on, fan speed goes up, and stays fast, TP stays black, nothing happens.
Workaround Suggestion:
Pressing and holding power button turns robot off, starting again works most times
Robot Serial Number:
brand new UR20 delivered with polyscope 5.25 .0
Affected Version(s):
in this case 5.25.0
also a problem for this case - Swith on problem - Technical Questions - Universal Robots Forum
It sounds like a faulty PSU. Could you also answer how often it happens?
I had only seen it 2 or 3 times, after the robot had been turned off for at least 12 hours in between
