I wanted to know if there is a way to read a .urp file into python. I know the urp file is a form of compressed xml format, but I can’t seem to get the correct encoding to read it in python.
This library has a Python wrapper that allows you to edit the XML inside a URP file.
from underautomation.universal_robots.files.ur_program import URProgram
import clr
clr.AddReference("System.Xml.Linq")
from System.Xml.Linq import XElement
prg = URProgram.load("path\\to\\program.urp")
xmlString = prg.xml.ToString()
## Edit xmlString
modifiedPrg = URProgram(XElement.Parse(xmlString))
modifiedPrg.save("path\\to\\program.urp")
Thanks for the library share, looks useful! Unfortunately it’s a bit overkill for my application.
I have found a way to open the file using gzip in python.
Example:
import gzip
with gzip.open("file.urp", "rb") as file:
file.readLine()
