Hey Friedrichs,
I just found your post here in the forum and read that you are using a soft PLC from Beckhoff.
I’m doing just the same but face quite some issues especially with the Profinet connection. My URs (I have two in use, CB3 Series), are often using profinet connection. Did you encouter the same issue and if so, did you find a solution, that you might could share with me.
Thank you in advance
Leon
