Is anyone able to help with the code that allows you to move a node up and down exactly as the buttons below do?
Thank you in advance.
Best regards.
Under certain circumstance, this use-case makes sense, i might find a feasible solution:
public void onMoveNodeClick(boolean is_move_up) {
final TreeNode cn = apiProvider.getProgramAPI().getProgramModel().getRootTreeNode(this);
//find current node
undoRedoManager.recordChanges(new UndoableChanges() {
@Override
public void executeChanges() {
// TODO Auto-generated method stub
try {
parent.setChildSequenceLocked(false);
treeindex = -1;
// let a private variable to find current node's index
parent.traverse(new ProgramNodeVisitor() {
public void visit(URCapProgramNode pn, int index, int depth) {
if(pn.canGetAs(Search1RotationCustomerAPI.class)) {
// it requires that every node in the sub-tree needs to have unique ID, i.e., here i make it into Display name.
if(pn.getAs(Search1RotationCustomerAPI.class).getDisplayName().equals(getDisplayName())) {
treeindex = index;
System.out.println("Current tree index is: "+index);
if(is_move_up) {
if(treeindex > 0) {
TreeNode toMove = parent.getChildren().get(treeindex-1);
parent.removeChild(cn);
parent.insertChildBefore(toMove, cn.getProgramNode());
}else {
if(treeindex < (parent.getChildren().size()-1)) {
TreeNode toMove = parent.getChildren().get(treeindex+1);
parent.insertChildAfter(toMove, cn.getProgramNode());
parent.setChildSequenceLocked(true);
}catch(TreeStructureException e15) {
e15.printStackTrace();
As a result:
how is this different than the up and down arrows already available?
It should be the same, it is useful when child nodes have been locked by urcap and user can still adjust its sequence.
