Implementing a Program node without extra command line
Hello
I have just recently started working with URCaps, i was testing my own implementation from the html example and i have not achieve to generate one URCap without the extra -Empty- command there, have you achieve to generate one of them without this extra command ? Any suggestions will be apretiated
Regards
Which value is isChildrenAllowed() of ProgramNodeService, true or false?
If value is false, the node implemented has no child empty nodes.
Thank you that worked perfectly!
