i would like to compare poses in my if-condition but i cant get it working.
def mvtoPick():
global speed_ms = 1.750
global speed_rads = 1.750
global accel_mss = 1.200
global accel_radss = 1.200
global blend_radius_m = 0.001
#Calculating Pose with Offset in Z-direction
offset_var = pose_trans(pose_trans(setbase, setpose), p[0,0,-0.1,0,0,0])
local target_pose = pose_trans(setbase,setpose)
#Function to calculate a midpoint with z-offset to ensure a safe approach
local Pose_Act = get_actual_tcp_pose() #Reads current TCP Pose
if(not(Pose_Act == setbase) and not(Pose_Act == offset_var) and not(Pose_Act == poseHome)):
local dist = pose_dist(Pose_Act, target_pose) #Calculates distance between the two points in m
Pose_Mittelpunkt = pose_add(interpolate_pose(Pose_Act, target_pose, 0.5), p[0,0, dist, 0,0,0]) #Calculates Point inbetween two poses and adds an offset in z-Axis
local dist_blend = pose_dist(Pose_Act, Pose_Mittelpunkt)/2 #Calcualtes value for blend radius
movej(Pose_Mittelpunkt, 1, .5,0 , dist_blend) #Moves to calculated point with calculated blend radius
else:
popup("Else funktion ausgeführt", title="Popup #1",blocking=True)
#Move to offset
movej(offset_var,accel_mss,speed_ms)
#Move to Position
movel(target_pose,accel_mss,speed_ms)
i start at the home position poseHome, which is predefined in the installation tab.
and immediatly get the act_tcp_pose but the condition is still met and executes the move.
What is the problem here?
It is suggested to print the Pose_Act, then compare with the poseHome set in installation. Maybe it is not exactly equal, the diff of XYZ shall be small.
What do you mean by printing? Is there a specific function for that or just save it in a variable and view it in the “Variables” Tab while running the problem?
Thanks for the help!
You could round them yes.
There is the ceil() and floor() functions to round to closest integer. I don’t remember a function that can round to a certain decimal place.
You could also use pose_dist() or point_dist() which calculates a distance between two poses and you can then check whether the distance is within a certain threshold.
Here is my final solution, where i get the current tcp and compare the distance.
def mvtoPick():
if((pose_dist(setbase, Pose_Act) > 0.01) and (pose_dist(offset_var, Pose_Act) > 0.01) and (pose_dist(poseHome, Pose_Act) > 0.01)): #If distance between current tcp and target greater than 10mm execute
#Move to offset
#Move to Position
Thank you for posting the solution.
Will be useful for others who run into this problem.
Comparing poses is a recurring challenge that is difficult to troubleshoot with the lack of debugging options available.
