Get Waypoint name
I’m working on a URCap where I need to collect the names of all waypoint that are children of my URcap node. I can successfully traverse the waypoint children using the code below and retrieve their poses (for fixed_position waypoints). However, I’m unsure how to retrieve the names of these waypoints as they appear in the program tree.
root.traverse(new ProgramNodeVisitor() {
			@Override
			public void visit(WaypointNode programNode, int index, int depth) {
                    // I can access the pose of FIXED_POSITION waypoints
					if (programNode.getConfig().getConfigType() == ConfigType.FIXED_POSITION) {
						try {
						FixedPositionDefinedWaypointNodeConfig cfg = (FixedPositionDefinedWaypointNodeConfig)programNode.getConfig();
						Pose pose = cfg.getPose();
						} catch (Exception e) {}
                    // I cannot find a function like this one to get the waypoint name
					String name = programNode.getName();
Is there a way to achieve this? Any guidance would be appreciated!
In case anyone faces the same issue, I found a solution. The toString() function of the Object class, which typically returns a string in the format class name + @ + hash code, has been overridden for objects of type WaypointNode to return the name of the waypoint as it appears in the program tree
