Force sensor data output
Hi All,
I’m trying to connect a force sensor to the UR16e control box and I want to get the force during the working process. But I don’t know how to do it. I’m using the URX to control the UR16e.
Is there any function I can use to get the force data?
Sorry, I studied the UR16e several days aso.
have you already taken a look at the URScript Manual? (This is the current version at the moment. Please make sure to use the latest/fitting manual version)
The function force() and get_tcp_force() provide you with the current force data of the robot during a running program.
Alternatively you can use the different interfaces available on the robot for accessing the robot force data:
sko
Thank you!
Yes.
Right now, I think I know how to get it.
Best,
Yong
Although quite some time have passed but can you guide me about getting the real time force data from UR16e? I am also new to the process and I am planning to work on sheet forming of very thin aluminum using this robot.
So I need to see the forming forces real time.
Your help and guidance will be appreciated.
