Hi all,
I have a UR3e and trying to depalletize a stack of 15 microplates (each 15mm thick) from a plate rack. After picking up each microplate, the arm needs to go up to a specific point above the plate rack to avoid collision.
However, I found that even though I taught the entry and exit points (relative to the reference position) in the depalletizing wizard, this entry/exit point goes lower after picking up each microplate from the stack, which results in the arm colliding with the top of the plate rack after the 5th microplate.
How do I make the entry/exit point consistent so that it does not go lower after each microplate pickup?
Thank you
