I have an esa automation panel that communicates with a UR3e in dashboard port 29999… The robot receives the commands of break released, manual, automatic… but when should I read the response string. for example, after the commando is in remote control, the string that i receive is equal to 0.Following the esa script :
''connection parameters
Dim serverIPAddress
serverIPAddress = “192.168.100.20” 'server ip
Dim serverIPPort
serverIPPort = 29999 'server port
Dim TCPClientID
TCPClientID = -1 'initialize TCPClient ID
’ open client communication
sub openCLIENT()
' if client not exists -> create!
if (TCPClientID = -1) then
TCPClientID = ESAHMI.ESAETH.TCPClient.OPEN(serverIPAddress, serverIPPort )
end if
ESAHMI.ESAMSGBOX "TCPClientID " & TCPClientID
end sub
'write command
sub wrstrcl ()
'check if client exists
ESAHMI.ESAMSGBOX “Client not exists”
exit sub
end if
Dim nChars
nChars = ESAHMI.ESAETH.TCPClient.WriteString(TCPClientID, "robotmode\n")
ESAHMI.ESAMSGBOX "TCPClient WriteString: " & nChars
end sub
'read a string
sub readstrcl()
ESAHMI.ESAMSGBOX "Client not exists"
exit sub
end if
Dim readBuffer
nChars = ESAHMI.ESAETH.TCPClient.ReadString (TCPClientID, readBuffer, 0)
if (nChars<>0) then
ESAHMI.ESAMSGBOX "TCPClient ReadString: " & nChars & " : " & readBuffer
else
end if
end sub
'close client communication
sub close ()
if (TCPClientID <> -1) then
ESAHMI.ESAETH.TCPClient.Close TCPClientID 'close client
TCPClientID = -1 'reset TCPClientID
ESAHMI.ESAMSGBOX "Client closed"
else
ESAHMI.ESAMSGBOX "Client already closed"
end if
end sub
