On a CB3 with the teach pendant, is there any way to copy and paste an entire program? I have a tip detect program that I’d like to replace that’s used in conjunction with other programs. However, it has the installation file attached to it. I just want to copy and paste the whole thing. Possible somehow?
Not sure if this is just a UI question but you can long press in the open file dialog to get access to copy. Then paste it somewhere else and associate a blank installation with it.
If it’s not a UI related question, inserting it as a subprogram into your other program could help?
it’s not quite clear how exactly you would like to insert the entire program. If you can, please elaborate on your question!
Or just describe what you would like it to look like.
Essentially, I wanted to take a new program tree, copy it into an older program, and then delete that older part of the program.
However, I think I’m over-complicating things. I can just do a save-as, put it in the file folder that I want, and then load the appropriate install file.
