Comunication Socket with Rockwell
Hello, I am doing a Rockwell L 36 plc configuration and a UR10, I am creating an MSG to close popup but I don’t know what are the values ​​instance, service code, class and attribute, does anyone know which value to put?
Hi Tiago,
To handle the popups in Polyscope you can access the Dashboard server:
https://www.universal-robots.com/how-tos-and-faqs/how-to/ur-how-tos/dashboard-server-cb-series-port-29999-15690/
If you need to do it from the URScript, there is an example here:
https://www.universal-robots.com/how-tos-and-faqs/how-to/ur-how-tos/create-informational-popups-in-run-screen-15382/
I have a rockwell PLC that I am using. I have the EDS installed along with the ethernet module. Where can I find a .csv file for the Tag descriptions? TIA
I am also trying to communicate with the dashboard server from a Rockwell PLC. Is there any example code for this situation?
Thank you, Terry
Hello Terry.
Send me an e-mail and I will provide you with the code I created.
tiago.nascimento@intereng.com.br.
Thank’s
