I tried to connect UR3e control box to Laser Marking controlling unit via Ethernet option but it doesn’t seem to work. I’m trying to implement a Master-Slave functionality. Master being UR3e. However, wasn’t able to achieve communication between those two.
Any suggestion please on how to achieve this?
Thanks.
For Ethernet IP connection you will need a separate PLC with Ethernet IP Scanner (Master)
this will need to be Master to both the Universal Robot and the Keyence laser marker.
You only really need it to pass signals through from one to the other.
Its a shame UR haven’t added the Ethernet IP Scanner option it would be so Handy.
