Hi All,
We need to clone all in SD card to other SD because on our will wipe the Data after POC completes.
.urcontrol folder /enable hidden folders
flightreports folder - if not present just ignore
.urpass.file - if not present just ignore
.ursafetypass.file - if not present just ignore
histogram.propeties
Log_history.txt
ur-serial
can someone guide how to take backup for these
or-else any other idea save Robot after wiping.
You can do a complete backup of the system from the settings menu in the upper right corner.
Don’t you think that will work for you?
I will take backup from there after that i need to install image to SD card and then i can restore everything from the settings menu in the upper right corner right?
Exactly. Just to be safe, you can also download the support file from the Log tab. The support file contains everything as well: programs, configuration files etc.
Just not network settings and passwords.
Hey,
I took backup from system tab but while restoring iam getting error like(Mount).
If i download support from log tab how to upload this to new Image installed SD card
That’s weird. Can you elaborate a bit on the error?
If you follow this tutorial, you should be able to restore the configuration files and programs. https://www.universal-robots.com/media/1804841/install-new-image-all-types.pdf
You will find the root folder, programs etc in your Support File backup.
Hello I have a similar error with a 10e 5.11 when trying to backup, it shows me an error,
ERROR: Not enough free space on device.
umount: /dev/mmcblk1p2: not mounted.
umount: /dev/mmcblk1p3: not mounted.
umount: /dev/mmcblk1p4: not mounted.
umount: /tmp/tmp.SHK9J9Ywe7/mnt: no mount point specified.
FAILURE (exit Code 1) - Please acknowledge by pressing Ok.
I’m with a 8gb pendrive.
i would re-format your thumb drive or try a different one.
I tried with other thumbdrive and now the problem is in the step 3 of the backup process
Looks like your image didn’t upload right.
