Changing from Local mode to Remote mode
I would like to switch the robot’s control mode from Local mode to Remote mode using a signal from the PLC. Is this possible?
Based on my research, it seems that the control mode can currently only be changed manually using the teach pendant.
Could you please let me know if there is a way to switch the control mode using a signal from the PLC?
There is no other documented way to swich to remote mode, and also I remember from Training that this is intended for safety reasons. Only one in front of the machine can judge if it is safe to switch to remote mode.
We also control one of our robots externally, but for that it is constantly in remote mode. Except when we teach something, but then it’s technical personnel, that will put it back to remote mode afterwards. Wouldn’t this be a solution for you, too?
