Can I achieve real-time speed control use MOVEP?
My script is as follows. I use UR5E and needs to change speed on every waypoint. But when I got TCP speed using speed = get_actual_tcp_speed() textmsg("TCP Speed: ", speed), I found the actual speed are different from the target speed even though I use a larger accel_mss (for example, the target speed is 0.019 but the actual speed may be 0.015,0.016 or 0.02). Is this right? how to exactly control the speed on every waypoint?
movep(p[-0.517287, 0.127085, -0.040110, -0.497385, -0.091463, 0.023245],accel_mss,speed_ms,0)
speed_ms= 0.014
socket_send_line(“G1 P1.0”, “socket_01”)
movep(p[-0.517999, 0.128532, -0.040803, -0.497385, -0.091463, 0.023245],accel_mss,speed_ms,0.001)
speed_ms= 0.014
movep(p[-0.518743, 0.129959, -0.041577, -0.497385, -0.091463, 0.023245],accel_mss,speed_ms,0.001)
speed_ms= 0.015
movep(p[-0.519365, 0.131118, -0.042319, -0.540721, -0.109104, 0.030271],accel_mss,speed_ms,0.001)
speed_ms= 0.015
movep(p[-0.520293, 0.132615, -0.043407, -0.580746, -0.126889, 0.037975],accel_mss,speed_ms,0.001)
speed_ms= 0.016
movep(p[-0.521024, 0.133727, -0.044299, -0.617815, -0.143469, 0.045875],accel_mss,speed_ms,0.001)
speed_ms= 0.016
movep(p[-0.521928, 0.134983, -0.045412, -0.650371, -0.158162, 0.053456],accel_mss,speed_ms,0.001)
speed_ms= 0.017
movep(p[-0.522787, 0.136140, -0.046534, -0.675862, -0.170250, 0.060000],accel_mss,speed_ms,0.001)
speed_ms= 0.018
movep(p[-0.523751, 0.137378, -0.047807, -0.693713, -0.179617, 0.065136],accel_mss,speed_ms,0.001)
speed_ms= 0.018
movep(p[-0.524739, 0.138472, -0.048999, -0.705641, -0.186872, 0.069054],accel_mss,speed_ms,0.001)
speed_ms= 0.018
movep(p[-0.525665, 0.139524, -0.050162, -0.714106, -0.192956, 0.072252],accel_mss,speed_ms,0.001)
speed_ms= 0.018
movep(p[-0.526680, 0.140497, -0.051298, -0.720629, -0.198357, 0.075033],accel_mss,speed_ms,0.001)
i would not be using moveP for variable speeds. your robot movement will be very sudden and jerky and will kill your joints super quick. that being said, safety will overrule any speed settings you have so make sure your safety settings aren’t hindering your tests.
