Hello
Im get this error while following the MyFirstURCap tutorial running mvn install -P ursim
[INFO] Results:
[INFO]
[INFO] Tests run: 1, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO]
[INFO] --- maven-bundle-plugin:2.4.0:bundle (default-bundle) @ lightup ---
[INFO]
[INFO] --- exec-maven-plugin:1.1:exec (package-urcap) @ lightup ---
[INFO]
[INFO] --- maven-install-plugin:2.5.2:install (default-install) @ lightup ---
[INFO] Installing /home/ur/workspace/com.UniWest.lightup/target/lightup-1.0-SNAPSHOT.jar to /home/ur/.m2/repository/com/UniWest/lightup/1.0-SNAPSHOT/lightup-1.0-SNAPSHOT.jar
[INFO] Installing /home/ur/workspace/com.UniWest.lightup/pom.xml to /home/ur/.m2/repository/com/UniWest/lightup/1.0-SNAPSHOT/lightup-1.0-SNAPSHOT.pom
[INFO]
[INFO] --- maven-bundle-plugin:2.4.0:install (default-install) @ lightup ---
[INFO] Installing com/UniWest/lightup/1.0-SNAPSHOT/lightup-1.0-SNAPSHOT.jar
[INFO] Writing OBR metadata
[INFO]
[INFO] --- exec-maven-plugin:1.1:exec (ursim-install-urcap) @ lightup ---
[INFO] cp: cannot create regular file '/home/ursim/ursim-5.11.ur0.108249/.urcaps/com.UniWest.lightup.jar': No such file or directory
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 2.694 s
[INFO] Finished at: 2022-08-19T13:14:13-07:00
[INFO] Final Memory: 16M/270M
[ERROR] Failed to execute goal org.codehaus.mojo:exec-maven-plugin:1.1:exec (ursim-install-urcap) on project lightup: Result of /bin/sh -c cd /home/ur/workspace/com.UniWest.lightup && cp target/lightup-1.0-SNAPSHOT.jar /home/ursim/ursim-5.11.ur0.108249/.urcaps/com.UniWest.lightup.jar execution is: '1'. -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
I can see that it is missing .jar, is that something i need to create myself? i cant recall doing this in the tutorial
//David
