We’d like to be able to query the safety planes defined on the robot through ROS, either by subscribing to a topic or calling a ROS service.
The desired use case is to be able to instantiate the identical planes in a MoveIt Planning Scene so that we can run the same types of configuration safety checks that are run on the robot, for example to make a smart teleoperation node that respects the safety setup of the robot itself.
Is this currently possible? If not, please consider it a feature request!
-Matt
